A wireless broadband communication system has many components; each one contributes to the overall performance and ultimately affects operator revenues. Well-designed components that complement each other will improve overall network performance, increase the longevity of the system and optimize operators’ profits.
One of the principal considerations in a communications system is antennas. Their impact is enormous - using the wrong antenna will degrade the overall performance of an otherwise well engineered system, resulting in customer dissatisfaction.
At Cambium Networks, our antennas are engineered to address most typical network and terrain challenges and built to the highest level quality and reliability. The 2.4 GHz Access Point 60 degree sector antennas are specifically designed for use with the 2.4 GHz PMP 450 platform of products. As a result of their consistent front-to-back ratio in combination with power control and high gain, these antennas deliver optimized performance, including maximized spectral efficiency and easy installation.
