ePMP 6 GHz Fixed Wireless Access 2×2 25 dBi Dish Antenna
These antennas are engineered specifically for the 6 GHz band. Aside from frequency coverage, the key advantage is focusing higher gain in the main bore sight while minimizing side lobes in
the propagation pattern.
• 25 dBi gain
• 5.150 to 7.125 GHz spectrum
• 28 dBi gain with range extender
• Compatible with Force 4600C
