cnMatrix™ EX2000 Series Switches Data Sheet Quick Look Zero-touch deployments Policy Based Automation Auto device profiling and segmentation Non-blocking, line-rate architecture with fully featured L2/L3 switching Download Full data sheet
cnMatrix EX2016M-P Switch 86 Gbps throughput, 2 SFP+ Uplink ports, 6 100M/2.5G Ports, 8 10/100/1000 Mbps Ports, 14…
cnMatrix EX2052-P Switch 176 Gbps throughput, 48 10/100/1000 Ports, 120 Forwarding Rate in Mpps (64 Byte Packets)
cnMatrix EX2052R-P Switch 176 Gbps throughputs, 48 10/100/1000 Ports, 120 Forwarding Rate in Mpps (64 Byte Packets), 4…
cnMatrix EX2028-P Switch 128 Gbps throughput, 24 PoE enabled ports, 24 10/100/1000 ports, 4 SFP+ Uplink ports
cnMatrix EX2010-P Switch 20 Gbps throughput, 8 PoE enabled ports, 8 10/100/1000 ports, 2 SFP Uplink ports, optional…
cnMatrix EX2010 Switch 20 Gbps throughput, 8 10/100/1000 ports, 2 SFP Uplink ports, optional rack mount kit
