4.9 to 5 GHz Dual Pole 90 Degree Sector Antenna Data Sheet
Quick Look
Cambium Networks has deployed millions of radios around the world, achieving unparalleled degrees of scalability. Based on this vast experience, Cambium Networks has designed a sector antenna solution for PTP 670/700 High Capacity MultiPoint (HCMP) radios that enables network operators to connect up to eight PTP radios to a single HCMP access point. Operators deploying networks in the 5GHz spectrum will find this sector antenna especially well-suited to high-density networks requiring frequency re-use and wide-band spectrum coverage, as well as video surveillance and mission critical infrastructure backhaul applications. This sector antenna is also compatible with Cambium Networks’ connectorized PMP products.
