Industrial applications require deployment in harsh environments where equipment must survive and operate at top performance during many years of mission critical use.
Cambium’s line of premium-grade industrial antennas is designed with the following key features and capabilities:
- Designed to withstand heavy ice, high wind, wide temperature
- swings and other harsh conditions.
- Manufactured using high strength aircraft-quality aluminum with all joints welded as well as the integral feed line welded
- for additional strength and improved electrical conductivity.
- Anodized surfaces for long life, improved aesthetics and corrosion resistance
- Mounting bracket included to support either Horizontal or Vertical polarization applications
- Available in both stand-alone and with an optional complete turn-key installation kit
- Integrated in Cambium’s LINKPlanner software for network planning of capacity and availability
