Video: Expand Service to 6 GHz Efficiently with PMP 450v
PMP 450v Fixed Wireless Access Point
Specifications
INTERFACE
Physical Layer
2x2 MIMO OFDM
Ethernet Interface
100/1000BaseT, full duplex, rate auto negotiated (802.3 compliant)
Protocols Used
IPv4, IPv6, UDP, TCP/IP, ICMP, Telnet, SNMP, HTTP, FTP
PERFORMANCE
Subscriber Per Sector
Up to 238
ARQ
Yes
Maximum Deployment Range
Up to 40 miles (64 km)
PHYSICAL
Weight
6.3 kg (13.9 lbs), 9.1 kg (20 lbs) with bracket
Dimensions (HxWxD)
673 x 222 x 134 mm (26.5 x 8.75 x 5.3 in.)
SECURITY
Encryption
FIPS-197 128-bit AES , 256-bit AES (Requires Optional License)
