PMP 450d features a 25 dBi integrated dish in a new, rugged design. PMP 450d is easy to assemble and deploy, and works with existing power supplies.
PMP 450d Integrated Subscriber Module Dish
Specifications
SPECTRUM
Frequency Range
5470 - 5875 MHz
Channel Width
5 MHz, 10 MHz, 15 MHz, 20 MHz, 30 MHz or 40 MHz
Channel Spacing
Selectable on 2.5 MHz increments
INTERFACE
Physical Layer
2x2 MIMO OFDM
Ethernet Interface
10/100/BaseT, half/full duplex, rate auto negotiated (802.3 compliant)
Protocols Used
IPv4, UDP, TCP, IP, ICMP, Telnet, SNMP, HTTP, FTP
PERFORMANCE
ARQ
YES
Maximum Deployment Range
Up to 40 miles
Latency
3 - 5 ms, typical
LINK BUDGET
Antenna Specifications
7° azimuth , 7° elevation , >30 dB front-to-back isolation
Integrated Dish Gain
25 dBi
Transmit Power Range
-30 TO +22 dBm (combined, to EIRP limit by region) (1 dB interval)
PHYSICAL
Antenna Connection
Integrated dish antenna
Environmental
IP55
Temperature
-40°C TO +60°C (-40°F TO 140°F), 0-95% non-condesnsing
Weight
3.5 kg (7.7 lbs)
Dimensions
Dish diameter – 47 cm (18.5 inches with Radome) Depth - 17 cm (6.6 inches)
SECURITY
Encryption
56-bit DES, FIPS-197 128-bit AES
