The PMP 450b Subscriber Module supports frequencies from 4.9 – 5.9 GHz and provides 300 Mbps aggregate throughput in a 40 MHz channel.
5 GHz PMP 450b Connectorized Subscriber Module
Specifications
SPECTRUM
Channel Spacing
Configurable on 2.5 MHz increments
Frequency Range
4900 - 5925 MHz
Channel Width
5 MHz, 10 MHz, 15 MHz, 20 MHz, 30 MHz, or 40 MHz
INTERFACE
Physical Layer
2x2 MIMO OFDM
Ethernet Interface
100/1000BaseT, full duplex, rate auto negotiated, 802.3 compliant
Protocols Used
IPv4, IPv6, UDP, TCP/IP, ICMP, Telnet, SNMP, HTTP, FTP
PERFORMANCE
Maximum Deployment Range
Up to 40 miles (64 km)
GPS Synchronization
Yes, synchronized by Access Point
Quality of Service
Diffserve QoS
PHYSICAL
Environmental
IP67
Weight
0.9 kg (2 lbs) including mounting bracket
Dimensions (HxWxD) (including mount)
24 x 4 x 9 cm (9.5” x 1.5” x 3.5”)
SECURITY
Encryption
FIPS-197 128-bit AES, 256-AES optional
