Cambium Networks 450 platform increases performance with the addition of the 450b Subscriber and Backhaul Module.
450b Retro
Specifications
SPECTRUM
Channel Spacing
Configurable on 2.5 MHz increments
Frequency Range
4900 - 5925 MHz
Channel Width
5 MHz, 10 MHz, 15 MHz, 20 MHz, 30 MHz or 40 MHz
INTERFACE
MAC (Media Access Control) Layer
Cambium Networks proprietary
Physical Layer
2x2 MIMO OFDM
Ethernet Interface
100/1000 BaseT, full duplex, rate auto negotiated, 802.3 compliant
Protocols Used
IPv4, IPv6, UDP, TCP/IP, ICMP, Telnet, SNMP, HTTP, FTP
Network Management
IPv4/IPv6 (dual stack), HTTP, HTTPS, Telnet, FTP, SNMPv2c and v3, Cambium Networks cnMaestroTM
SECURITY
Encryption
FIPS-197 128-bit AES, 256-bit AES
(Requires Optional License for attached Access Point)
450b Retro
Documentation
No Case Studies currently available.
No Solution Papers currently available.
No Videos currently available.
No Webinar Replays currently available.
