Purpose-built for fixed wireless broadband, key features of the solution include:
  • 5G-NR protocol and frame structure – optimized for fixed wireless to maximize throughput and reduce complexity, but retain the ability to coexist with standards-based products
  • Multi-User MIMO – leveraging Cambium Networks’ industry-leading and field-proven massive MU-MIMO technology that provides up to 8 simultaneous data streams to CPEs
  • Beamforming – proven Cambium Networks technology to optimize performance and isolate noise
  • Automated provisioning – to streamline installation and provisioning
BTS Features
  • 24, 26 and 28 GHz bands in a single SKU
    • n257 (26.50 – 29.50 GHz), 28 GHz, TDD​
    • n258 (24.25 – 27.50 GHz), 26 GHz, TDD​
    • n261 (27.50 – 28.35 GHz), 28 GHz US, TDD​
  • TDD only
    • DL:UL supported TDD ratios are 4:3, 5:2 or 6:1​
    • Same channel for Uplink/Downlink, or​
    • Different channel for Uplink/Downlink (for easier deployment alongside FDD system)​
  • Support either V or H polarization (single SKU)
    • Polarization is configurable independently for each sector
  • Support the following channel sizes
    • 112 & 56 MHz (legacy)​
    • 100 & 50 MHz (5G allocation)​
  • Carrier aggregation
    • Support up to 2 operating channels of the same Channel BW​
    • Channels may be non-adjacent​
    • Examples:​
      • Single 112 MHz carrier, with 8×8 MIMO per carrier, or​
      • Dual 112 MHz carrier, with 4×4 MIMO per carrier
cnWave 5G Fixed Base Transceiver Station
Specifications
SPECTRUM
Frequency Range
24.25 ~ 29.50 GHz
Channel Width
50, 56, 100, 112 MHz channels
INTERFACE
MAC (Media Access Control) Layer
5G NR air Interface
Ethernet Interface
10/100/1000BaseT, SFP support for 1 Gbps or 10 Gbps optical
User Traffic
Ethernet Layer 2
Network Management
IPv4/IPv6 (dual stack), HTTP/HTTPS, TFTP, SNMPv2c and v3 Cambium Networks cnMaestro™
VLAN
802.1ad (DVLAN Q-inQ), 802.1Q with 802.1p priority; dynamic port VID learning
PERFORMANCE
Maximum EIRP
+44 dBm
Hybrid ARQ
Yes, DL and UL
Maximum Deployment Range
Up to 10 km (6.4 miles)
Latency
10 ms, typical
TDD Synchronization
Embedded GPS, sync-over-power or IEEE1588v2
SECURITY
Encryption
FIPS-197 128-bit AES, 256-bit AES
