Cambium Networks’ ePMP™ Force CSML is designed to operate in high interference environments and provides superior throughput of over 400 Mbps of real user data.
ePMP Force 300 CSML Connectorized Subscriber Module
Specifications
SPECTRUM
Channel Width MHz
20 | 40 | 80
Proprietary Physical Layer
2x2 MIMO/OFDM
Channel Spacing
Configurable in 5 MHz increments
Frequency Range
Wide Band Operation 4910–6200 MHz
Ethernet Interface
10/100/1000 BaseT
Network Management
IPv4/IPv6, HTTPs, SNMPv2c, SSH, Cambium Networks cnMaestro
PERFORMANCE
ARQ
Yes
Nominal Receive Sensitivity (w/FEC) @20 MHz Channel
MCS0 = -89 dBm; MCS9 = -62 dBm
Nominal Receive Sensitivity (w/FEC) @40 MHz Channel
MCS0 = -86 dBm; MCS9 = -60dBm
Nominal Receive Sensitivity (w/FEC) @80 MHz Channel
MCS0 = -84 dBm to MCS9 = -57 dBm
Modulation Levels (Adaptive)
MCS0 (BPSK) to MCS9 (256 QAM 5/6)
Transmit Power Range
+3 to 27 dBm (combined, to regional EIRP limit) (1 dB interval)
PHYSICAL
Surge Suppression
1 Joule Integrated
Environmental
IP55
Temperature
-30°C to 60°C (-22°F to 140°F)
Weight
0.49 kg (1.08 lbs)
Wind Survival
200 km/h (124 mph)
