ePMP Force 300-25L
Specifications
SPECTRUM
Channel Spacing
Configurable in 5 MHz increments
Frequency Range
Wide Band Operation 4910–6200 MHz
Channel Width MHz
20 | 40 | 80
PERFORMANCE
Nominal Receive Sensitivity (w/FEC) @20 MHz Channe
MCS0 = -89 dBm;
MCS9 = -62 dBm
Nominal Receive Sensitivity (w/FEC) @40 MHz Channel
MCS0 = -86 dBm;
MCS9 = -60dBm
Nominal Receive Sensitivity (w/FEC) @80 MHz Channel
MCS0 = -84 dBm to MCS9 = -57 dBm
PHYSICAL
Environmental
IP55
Temperature
-30°C to 60°C (-22°F to 140°F)
Weight
1.6 kg (3.5 lbs)
Dimensions
280 x 470 x 470 mm (11.0 x 18.5 x 18.5 in.)
SECURITY
Encryption
128-bit AES (CCMP mode)
