Cambium Networks’ ePMP product line has set the standard for high performance, scalability and reliability in harsh interference environments, all at a compelling price. The ePMP 4500 Access Point series is the fourth generation based on 802.11ax technology. ePMP 4500 Access Points series interoperate with Force 4500 Subscriber Modules. A sophisticated scheduling and QoS engine combined with TDD synchronization allows the ePMP 4500 Access Point series to deliver consistently high-quality service plans to a large number of end users.
Key Specifications
  • High-performance, scalable and reliable access points for fixed wireless broadband
  • Features MU-MIMO for up to 4 Gbps in 5 GHz
  • Available in 3 options: Integrated 90-degree Sector (4500) and Connectorized (4500C and 4500L)
  • Low TCO with three-year hardware warranty
  • Interoperable with all Force 4500 radios
  • Cloud or on-premises network management with cnMaestro
What's in the Box and How to Install
ePMP 4500 / 4500C / 4500L 5 GHz Fixed Wireless Access Point
Specifications
Spectrum
Channel Spacing
Configurable on 5 MHz increments
Frequency Range
Wide Band Operation 4910-6135 MHz
Channel Width
20 | 40 | 80 MHz
Interface
MAC (Media Access Control) Layer
Cambium Proprietary
Proprietary Physical Layer
ePMP 4500 and 4500C 8x8 MU-MIMO/OFDMA based on 802.11ax underlying technology. ePMP 4500L 2x2 MIMO/OFDMA based on 802.11ax underlying technology
Performance
ARQ
Yes
Nominal Receive Sensitivity (w/FEC) @20 MHz Channel
MCS 0 = -91 dBm to MCS 13 (4096 QAM-5/6) = -62 dBm (per chain
Nominal Receive Sensitivity (w/FEC) @40 MHz Channel
MCS 0 = -88 dBm to MCS 13 (4096 QAM-5/6) = -59 dBm (per chain)
Nominal Receive Sensitivity (w/FEC) @80 MHz Channel
MCS 0 = -85 dBm to MCS 13 (4096 QAM-5/6) = -57 dBm (per chain)
