ePMP™ 1000 Connectorized Radio
Specifications
SPECTRUM
Channel Spacing
Configurable on 5 MHz increments
Frequency range
5 GHz: 4910 – 5970 MHz (exact frequencies as allowed by local regulations) 2.4 GHz: 2402 – 2472 MHz
Channel Width
5 | 10 | 20 | 40 MHz
INTERFACE
MAC (Media Access Control) Layer
Cambium Proprietary
Physical Layer
2x2 MIMO/OFDM
Ethernet Interface
100 BaseT, Cambium PoE (V+ = pins 7 & 8, Return = pins 4 & 5)
Protocols Used
IPv4/IPv6 (Dual Stack), UDP, TCP, ICMP, SNMPv2c, NTP, STP, IGMP, SSH
Network Management
IPv4/IPv6, HTTPs, SNMPv2c, SSH, Cambium Networks CnMaestro™
VLAN
802.1Q with 802.1p priority
PERFORMANCE
ARQ
Yes
Nominal Receive Sensitivity (w/FEC) @ 20MHz Channel
MCS0 = -93 dBm to MCS15 = -69 dBm (per branch)
Nominal Receive Sensitivity (w/FEC) @ 40MHz Channe
MCS0 = -90 dBm to MCS15 = -66 dBm (per branch)
Modulation Levels (Adaptive)
MCS0 (BPSK) to MCS15 (64QAM 5/6)
Quality of Service
Three level priority (Voice, High, Low) with packet classification by DSCP, COS, VLAN ID, IP & MAC Addr, Broadcast, Multicast and Station Priority
LINK BUDGET
Transmit Power Range
-17 to +30 dBm (combined, to regional EIRP limit) (1 dB interval)
PHYSICAL
Antenna Connection
50 ohm, RP (Reverse Polarity) SMA (2)
Surge Suppression
1 Joule Integrated
Environmental
IP55
Temperature
-30°C to +60°C (-22°F to +140°F)
Weight
0.49 kg (1.1 lb.)
Wind Survival
145 km/hour (90 mi/hour) when mounted on ePMP Sector Antennas
Dimensions (h x w x d)
29.1 x 14.5 x 8.3 cm (11.4 x 5.7 x 3.3 in)
Power Consumption
7 W Maximum, 5 W Typical
Input Voltage
10 to 30 V
SECURITY
Encryption
128-bit AES (CCMP mode)
CERTIFICATIONS
FCCID
2.4 GHz: Z8H89FT0011 / 5 GHz : Z8H89FT0006
Industry Canada Cert
2.4 GHz: 109W-0011 / 5 GHz : 109W-0006
CE
5.4 GHz: EN 301 893 V2.1.1 5.8 GHz: EN 302 502 V2.1.1
