Designed for PTP 650 Series, the PTP Sync Unit module synchronizes multiple PTP 650 connections by providing a common clock signal and GPS signal reference.
PTP Sync Unit
Specifications
RADIO TECHNOLOGY
TIMING INPUT SIGNAL
1 Hz or 1 PPS (pulse per second) received from a timing device (GPS module, CMM or other synchronized timing device); PTP-SYNC unit can maintain local synchronization between collocated radios when timing is unavailable
SYSTEM CONFIGURATION
One PTP-SYNC unit per link; up to 10 PTP-SYNC units can be daisy-chained to one timing source
POWERING
LED INDICATOR
Power status, GPS and SYNC activity
POWERING
56 V DC, phantom powering from PIDU/ODU cable
CABLE
Standard Cat-5e
CONNECTION
Standard RJ-45
PHYSICAL
DIMENSIONS
Width 7.1” (180 mm), Height 1.4” (35 mm), Depth 3.1” (80 mm), Weight 1.32 lbs (0.6 kg)
OPERATING TEMPERATURE
-40°F (-40°C) to +140°F (+60°C), including solar radiation
HUMIDITY
Up to 95% non-condensing
POWER SUPPLY
Integrated with Indoor Unit
OPERATING VOLTAGE
+39.0 V to +60.0 V, measured at the terminals of the unit
POWER CONSUMPTION
1.5 W max at the terminals of the unit
