PTP 850E E-band Radio, an ultrahigh capacity, all-outdoor Ethernet backhaul operating in the E-band (71‒86 GHz). PTP 850E supports 250, 500, 1000, and 2000 MHz channels with BPSK to 512 QAM and delivers up to 10 Gbps capacity in 1+0 configuration. PTP 850E can also be used in multiband configuration with PTP 820C, PTP 820S, or third-party microwave radios to provide robust links of up to 10 Gbps.
PTP 850E
Specifications
RADIO
Radio Specs
71-76 GHz, 81-86 GHz
1+0, 2+0 (XPIC)*
Multiband with PTP 820C Radio Features
Radio Features
BPSK to 512 QAM with hitless ACM
Adaptive Coding Modulation and Bandwidth (ACMB)
ATPC*
Adaptive Bandwidth Notification (ABN)*
ETHERNET
Ethernet Interfaces
Port 1: DC port
Port 2: RJ45, 1 GE/Management/PoE
Port 3: SFP cage, 1/ 2.5 GE Multiband Port
Ethernet Features
MTU – 9612 Bytes
4K VLANs
VLAN add/remove/translate
Y.1731 Ethernet OAM
Adaptive Bandwidth Notification (ABN), also known as EOAM
TECHNICAL SPECIFICATIONS
Mechanical Specs
Dimensions (Direct Mount): 322mm(H), 227/270mm(W), 86mm(D), 5.5kg
Dimensions (43dBi integrated Antenna): 341mm(H), 270/276mm(W), 103mm(D), 7kg
Pole Diameter Range (for Remote Mount Installation): 8.89 cm – 11.43 cm
Environmental Spec
-33°C to +55°C (-45°C to +60°C extended)
-27°Fto +131°F (-49°Fto +140°F extended)
Power Input Specifications
Standard Input: -48 VDC
IDU DC Input range: -40.5 to -60 VDC
Power Redundancy option by using both a DC power input and a passive PoE injector simultaneously
