All outdoor, dual core, High Power 35 dBm model inter-operable with PTP 820C. The PTP 820C HP has up to 1.2 Gbps and field changeable diplexer.
PTP 820C HP
Specifications
RADIO
Frequency
6-11 GHz
Frequency
1+0, 2+0 SP/DP, 2+0 XPIC
Features
Field Changeable Diplexers Radio Features
Features
Multi-Carrier Adaptive Bandwidth Control (up to 2+0)
ETHERNET
Ethernet Interfaces
Traffic Interfaces – 1 x 10/100/1000Base-T (RJ-45) and 1x1000base-X (SFP) or 10/100/1000 Base-T (Electrical SFP)
Management Interface
1 x 10/100 BaseT (RJ-45)
Optical SFP Types
Optical 1000Base-LX (1310 nm) or SX (850nm) Note: SFP devices must be of industrial grade (-40°C to +85°C)
Ethernet Features
MTU – 9600 Bytes
Features
4K VLANs
Features
VLAN add/remove/translate
Frame Cut Through
Controlled latency and PDV for delay sensitive applications
Support
SSM/ESMC Support for ring/mesh applications (ITU-T G.8264)
Features
Sync-E Regenerator mode, providing PRC grade (ITU-T G.811) performance for smart pipe applications.
SYNCHRONIZATION
Synchronization
Sync Distribution over any traffic interface (GE/FE)
Synchronization
Sync-E (ITU-T G.8261, G.8262)
PTP 820C HP
Documentation
No Solution Papers currently available.
- SFP Guide
- cnMaestro Quick Start Guide
- Cable Guide
- Cambium Networks Sub-6GHz Antenna Guide
- PTP 820 Split Mount User Guide 11.3
- PTP 820 C-HP Installation Guide 11.5
- PTP 820 NMS Installation Guide (v10.9)
- PTP 820 NMS User Guide (v10.9)
- PTP 820 Series MIB Reference Guide
- PTP 820 RFU-D-HP Split Mount Installation Guide (v10.9)
No Videos currently available.
No Webinar Replays currently available.
