PTP 820C is an all-outdoor, multi-core unit. The PTP 820C has dual-core functionality enabling the system to operate up to 2 Gbps via software upgrades, eliminating the need for future forklift upgrades, or major system overhaul by the network operator to deliver gigabit-plus capacity.
PTP 820C
Specifications
RADIO
Frequency
6-38 GHz
Frequency
1+0 to 4+0, 1+1/2+2 HSB, E/W, 1+0 SD, 2+2 SD
Bandwidth Control
Multi-Carrier Adaptive Bandwidth Control (up to 2+0)
Protection
1+1/2+2 HSB
Protection
QPSK to 2048 QAM w/ACM
Features
2x2 / 4x4 MIMO
Features
Advanced Frequency Reuse (AFR)
ETHERNET
Traffic Interfaces
1 x 10/100/1000Base-T (RJ-45) and 1x1000base-X (SFP) or 10/100/1000 Base-T (electrical SFP)
Management Interface
1 x 10/100 BaseT (RJ-45)
Optical SFP Types
Optical 1000Base-LX (1310 nm) or SX (850nm)
TECHNICAL
Dimensions
230mm(H), 233mm(W), 98mm(D), 6.5kg
Pole Diameter Range (for Remote Mount Installation)
8.89 cm – 11.43 cm
Environmental
-33°C to +55°C (-45°C to +60°C extended)
