cnWave 60 GHz
Sub 6 High Capacity Backhaul
PTP 550
Multicore Gigabit Radio – Performance in the presence of InterferencePTP 670
Field proven high reliable backhaul for small cell and critical infrastructurePTP 700
One radio, multiple missionsPTP 45700 Beam Steering ODU
The PTP 45700 Beam Steering ODU with integrated Smart Antenna provides electronic beamforming that allows for easy tactical installation and best-in-class interference mitigation in addition to the industry-leading spectral efficiency and processing capabilities of the PTP 700 family of products.Licensed Microwave Backhaul
PTP 850EX
Capable of 1024 QAM with ACM, Supports 71-76 GHz, 81-86 GHzPTP 850E
All outdoor, 71-86 GHz, up to 10 GbpsPTP 850C
PTP 850C is next generation all-outdoor, multi-core unit. The PTP 850C has dual-core functionality enabling the system to operate up to 4 Gbps and deliver gigabit-plus capacity.PTP 820A
Split mount, multi-carrier, up to 1 GbpsPTP 820C
All outdoor, dual core, up to 1.2 GbpsPTP 820C HP
All outdoor, dual core, High power 35 dBm, up to 1.2 GbpsPTP 820S
All outdoor, single core, up to 600MbpsPTP 820E
All outdoor, 71-86 GHz, up to 2.5 GbpsPTP 820G
Split mount, multi-carrier, up to 1 GbpsPTP 820F
Split Mount Aggregation Node, up to 2.5 GbpsPMP 450 Backhaul family
PTP 450i Fixed Wireless Backhaul
Fit to comprehensive network with dynamic interference filteringPTP 450b
Backhaul links are the vital infrastructure that connects the network. You need confidence that your solution will work under heavy demand, regardless of the conditions. Licensed and unlicensed point-to-point (PTP) solutions from Cambium Networks perform reliably so that you can focus on your business. The PTP 450b features up to…5 GHz PMP 450b High Gain Subscriber Module
Up to 300 Mbps in a 40 MHz channel. Frequency range is 4.9 – 5.925 GHzPTP 450
Backhaul solution in 3.65 GHz lightly licensed and 3.5 GHz licensed bandsePMP Backhaul Family
ePMP Force 300-25
Cambium Networks’ ePMP Force 300-25 is designed to operate in high interference environments and provides superior throughput of over 500 Mbps of real user data.ePMP Force 425
Cambium Networks introduces the ePMP Force 425 point to point solution delivering up to 1 Gbps throughput at a breakthrough price point based on the latest 802.11ax standards.ePMP Force 300-19R
Combining the latest 802.llac Wave 2 technology and the field proven scalable performance of ePMP, the Force 300-19R delivers up to 600 Mbps of capacity. The Force 300-19R is a powerful yet affordable subscriber module compatible with the ePMP3000 Access Point and using the forward compatibility features also interoperates with…Tower Switches
cnMatrix TX2012R-P Switch
104 Gbps throughput, 8 PoE+ enabled ports, 8 10/100/1000 Mbps ports, 4 SFP+ Uplink portscnMatrix TX2020R-P Switch
112 Gbps throughput, 16 PoE+ enabled parts, 16 10/100/1000 Mbps ports, 4 SFP+ Uplink portsDocumentation
- PTP 820A Data Sheet
- N000000L054B: 240W Single Output Switching Power Supply
- PMP 450V 2×2 Fixed Wireless Subscriber Module and PTP Backhaul
- PTP 850EX Data Sheet
- PTP 550E Data Sheet
- PTP 550 Data Sheet
- PMP 450V 4×4 Fixed Wireless Subscriber Module and PTP Backhaul
- PTP 45700 Beam Steering ODU
- PTP 820G License Microwave Radio
- PTP 78700 Fixed Wireless Backhaul Data Sheet
- 7 and 8 GHz PTP 700 Ultra-Wideband Datasheet
- PTP 45700 Fixed Wireless Backhaul Data Sheet
- 2ft 5.25–5.85 GHz High-Performance Antenna
- Ruggedized Enhanced Power Injector (R-EPI) Data Sheet
- Tactical Deploy 90 (TD 90) Data Sheet
- PTP 450i
- PTP 850C Data Sheet
- PTP 850S Data Sheet
- 450b Retro Data Sheet
- LinkPlanner Data Sheet
- PTP 820F
- PTP 850E Data Sheet
- PTP 820 Network Management System
- PTP 820E Data Sheet
- cnPulse Data Sheet
- PTP 670 Data Sheet
- PTP 550
- Rugged Outdoor Cable
- PTP 820C HP Data Sheet
- PTP 820S FCC/IC 24 GHz Licensed Microwave Radio
- PTP 700 HCMP
- NTIA PTP 820G FIPS-140
- NTIA PTP 820C FIPS-140
- PTP 450 900 MHz
- PTP 820i All Indoor Data Sheet
- Intelligent Positioners Data Sheet
- 56v Gigabit Ethernet Surge Suppressor Data Sheet
- PTP 820G Data Sheet
- PTP 650 Sync Unit
- PTP 650 LPU
- PTP 650 NIDU
- PTP Sync Unit
- PTP 820C Data Sheet
- PTP 820S Data Sheet
- PTP 810i Data Sheet
- PTP 810 Data Sheet
- PTP 800i Data Sheet
- PTP 800 Data Sheet
- PTP 800 7-8GHz Data Sheet
- PTP 650 Data Sheet
- PTP 650S Data Sheet
- PTP 650L Data Sheet
- PTP 600 Data Sheet
- PTP 600 4.5-4.8 GHz Data Sheet
- PTP 500 Data Sheet
- PTP 450 Data Sheet
- PTP 230 Data Sheet
- PTP 200 250 Data Sheet
- PTP 100 Data Sheet
