PTP 800
Specifications
RADIO TECHNOLOGY
ODU-A RF bands
L6 GHz Band: 5.925 – 6.425 GHz U6 GHz Band: 6.425 – 7.100 GHz 7 GHz Band: 7.125 – 7.9 GHz 8 GHz Band: 7.725 – 8.47 GHz 11 GHz Band: 10.7 – 11.7 GHz 13 GHz Band: 12.75 – 13.25 GHz 15 GHz Band: 14.4 – 15.35 GHz 18 GHz Band: 17.7 – 19.7 GHz 23 GHz Band: 21.2 – 23.6 GHz 26 GHz Band: 24.25 – 26.5 GHz 28 GHz Band: 27.5 – 29.5 GHz 32 GHz Band: 31.8 – 33.4 GHz 38 GHz Band: 37.0 – 40.0 GHz
ODU-B RF bands
11 GHz Band: 10.7 – 11.7 GHz 18 GHz Band: 17.7 – 19.7 GHz 23 GHz Band: 21.2 – 23.6 GHz
Channel Size
Configurable from 7 to 80 MHz
Maximum Tx power
30 dBm
Best Rx sensitivity
-90.9 dBm
Security and encryption
Proprietary air interface
ETHERNET BRIDGING
Protocol
IEEE 802.3 802.1p/1Q (served by 8 queues) 802.1ad (Q-in-Q)
Frame size
Up to 9600 bytes
Latency
To < 115 µs @ full capacity with 64 bytes
MANAGEMENT & INSTALLATION
Network management
Inband and out-of-band
System management
IPv6/IPv4 dual-stack management support Web access via browser using HTTP or HTTPS/TLS7 SNMP v1, v2c, v3, MIB II, and proprietary PTP MIB Cambium Wireless Manager, release 3.0 or higher Motorola ASTRO® Unified Event Manager (UEM) Remote authentication using RADIUS and syslog
Out-of-band interface
10 / 100 Base T (RJ-45)
Installation
ODU – RSSI output assistance for link alignment
PHYSICAL
Physical configuration
Split mount – Compact Modem Unit (CMU) and Outdoor Unit (ODU)
Dimensions
ODU: Diameter 10.5” (26.7 cm), Depth 3.5” (8.9 cm) CMU: Width 7.1” (18.0 cm), Height 1.4” (3.5 cm), Depth 8.7” (22.0 cm)
Weight
ODU-A: 10.1 lbs (4.6 kg) ODU-B: 8.6 lbs (3.9 kg CMU: 2.4 lbs (1.1 kg)
Wind speed survival
ODU: 150 mph (242 kph)
Power source
-48V DC (-40.5V DC to -60V DC)
ENVIRONMENTAL & REGULATORY
Operating temperature
Outdoor Unit: -27° to +131° F (-33° to +55° C) – EN 300 019-1-4 Compact Modem Unit: -27° to +131° F (-33° to +55° C) – EN 300 019-1-3
Humidity
Outdoor Unit: Up to 100% Compact Modem Unit: Up to 95%, non-condensing
Safety
UL 60950; IEC 60950; EN 60950; CSA 22.2 No. 60950
