PTP 650S is a single unit module optimized for small cell backhaul applications. PTP 650S meets the performance, timing (IEEE 1588v2 and Synchronous Ethernet), reliability and security requirements of the latest generation mobile networks. PTP 650S simplifies the installation in all kinds of urban and rural environments. With built in alignment tools and flexible management interfaces, network operators can plan, install, monitor and support their network while keeping cost low. Includes the full suite of high performance capabilities including: Fast Adaptive Modulation, near and Non Line of Sight connectivity, layer 2 bridge implementation, symmetric and asymmetric TDD operation, and two Gigabit Ethernet ports.
PTP 650S
Specifications
RADIO TECHNOLOGY
RF BANDS
Wide-band operation 4.9 to 6.05 GHz (allowable frequencies and bands are dictated by individual country regulations. The most common bands are listed here.) 4.940 – 4.990 GHz (Public safety) 5.15 – 5.25 GHz 5.25 – 5.35 GHz 5.470 – 5.725 GHz 5.725 – 5.850 GHz 5.825 – 6.050 GHz 2.5 – 2.6 GHz3 3. .3 – 3.6 GHz3
CHANNEL SIZES
5, 10, 15, 20, 30, 40, and 45 MHz channels Channel sizes depend on individual country regulations
SPECTRAL EFFICIENCY
10 bps/Hz maximum
CHANNEL SELECTION
By dynamic spectrum optimization or manual intervention; Automatic selection on start-up and continual self-optimization to avoid interference
MAXIMUM TRANSMIT POWER
Up to 27 dbm at bPsK; up to 23 dbm at 256 QaM
SYSTEM GAIN
Integrated: Up to 160 db with 20 MHz channel and integrated 19 dbi antenna; Varies with modulation mode, Channel size and spectrum
RECEIVER SENSITIVITY
-98 dbm with 5 MHz channel
MODULATION / ERROR CORRECTION
Fast Preemptive adaptive Modulation featuring 13 modulation / FeC coding levels ranging from bPsK to 256 QaM dual payload MiMo
DUPLEX SCHEME
Synchronized Time division duplex (Tdd) and Half duplex Frequency division duplex (Hd-Fdd); dynamic or fixed transmit/receive ratio; each Tdd-synchronized link requires a Cambium Tdd-synC synchronization unit5 to provide an accurate timing reference signal
ANTENNA
Integrated: Flat panel – 19 dbi
RANGE
Software limited to 1.25 miles (2.0km); optional software license key to enable long-range applications
SECURITY
FiPs-197 compliant 128/256-bit aes encryption (optional) HTTPs and snMPv3 Identity-based user accounts Configurable password rules User authentication and Radius support Event logging and management; optional logging via syslog disaster recovery and vulnerability management
ETHERNET BRIDGING
PROTOCOL
IEEE 802.3
USER DATA THROUGHPUT
Dynamically variable up to 450 Mbps Maximum conditions – 2x2, 45 MHz channel1, 256 QaM
LATENCY
1 – 3 ms one-direction latency
QoS
8 Queues
PACKET CLASSIFICATION
Layer 2 and layer 3 ieee 802.1p, MPls, ethernet priority
LINE RATE ( >850K PACKETS PER SECOND)
Line rate ( >850K packets per second)
TIMING TRANSPORT
Synchronous ethernet; IEEE 1588v2
FRAME SUPPORT
Jumbo frame up to 9600 bytes
FLEXIBLE I/O
2x Gigabit ethernet copper ports: Gigabit Port 1: data + Poe power input Gigabit Port 2: 802.3at Poe output port (optional) sFP port (single-mode fiber, multi-mode fiber, and copper Gigabit ethernet options available)
T1/E1 TDM SUPPORT
8 x T1/e1 TdM module (optional indoor unit)3 G.823-compliant timing dC power input (compatible with aC+dC Power injector output)
T1/E1 LATENCY (ONE WAY)
1 to 3 ms typical depending on range, bandwidth, modulation mode and number of T1/e1 ports; Accurate T1/e1 latency figures can be determined for any given configuration using the Cambium PTP linKPlanner
MANAGEMENT AND INSTALLATION
LED INDICATORS
Power status, ethernet link status, and activity on extended Range Poe supply
NETWORK MANAGEMENT
In-band and out-of-band management (oobM)3
SYSTEM MANAGEMENT
iPv6/iPv4 dual-stack management support Web access via browser using HTTP or HTTPs/Tls4 snMP v1, v2c and v3, Mib-ii and proprietary PTP Mib Cambium Wireless Manager, WM 4.0/sP4 or higher online spectrum analyzer (no impact on payload traffic or network operation)
INSTALLATION
Built-in audio and graphical assistance for link optimization
CONNECTION
Distance between outdoor unit and primary network connection: up to 330 feet (100 meters) using Power-over-Gigabit ethernet; longer distances up to 984 feet (300 meters) can be achieved using fiber interface
PHYSICAL
DIMENSIONS
Integrated outdoor unit (odu): Width 207mm (8.2”), Height 306mm (12.0”), depth 69mm (2.7”): Weight integrated odu: 4.1 kg (8.95 lbs) including bracket operating temperature -40° to +140° F (-40° to +60° C), including solar radiation dust-water intrusion protection iP66 and iP67
WIND SPEED SURVIVAL
200 mph (322 kph)
POWER SUPPLY
Two options: aC power injector: 32° to 104° F (0° to +40° C); 35 W; 90-240 vaC, 50/60 Hz dimensions: Width 5.2” (132mm), Height 1.4” (36mm), depth 2” (51mm) aC + dC power injector: -40° to 140° F (-40° to +60° C); 70 W; 90-240 vaC, 50/60 Hz dimensions: Width 9.75” (250 mm), Height 1.5” (40 mm), depth 3” (80 mm)
POWER CONSUMPTION
30 W maximum
ENVIRONMENTAL AND REGULATORY
PROTECTION AND SAFETY
ul60950-1; ieC60950-1; en60950-1; Csa-C22.2 no. 60950-1; Cb approval for Global
RADIO
-4.9 GHz: FCC Part 90y, Rss-111 5.x GHz: FCC Part 15, sub-parts 15C and 15e; Rss 210 issue 8; en 302 502; en 301 893 eire ComReg 02/71R1, uK approval to iR2007
EMC
Europe – en 301 489-1 and -4
