PTP 650L
Specifications
RADIO TECHNOLOGY
RF BANDS
Wide-band operation 4.9 to 6.05 GHz (allowable frequencies and bands are dictated by individual country regulations. The most common bands are listed here.) 4.940 – 4.990 GHz (Public safety) 5.15 – 5.25 GHz 5.25 – 5.35 GHz 5.470 – 5.725 GHz 5.725 – 5.850 GHz 5.825 – 6.050 GHz
CHANNEL SIZES
5 / 10 / 15 / 20 / 30 MHz channels Channel sizes depend on individual country regulations
SPECTRAL EFFICIENCY
10 bps/Hz maximum
CHANNEL SELECTION
By dynamic spectrum optimization or fixed frequency assignment; automatic selection on start-up and continual self-optimization to avoid interference
MAXIMUM TRANSMIT POWER
Up to 27 dbm at BPSK; up to 23 dBm at 256 QAM
SYSTEM GAIN
Integrated: up to 160 dB with 20 MHz channel and integrated 19 dBi antenna; varies with modulation mode, channel size and spectrum
RECEIVER SENSITIVITY
-98 dBm with 5 MHz channel
MODULATION / ERROR CORRECTION
Fast Preemptive Adaptive Modulation featuring 13 modulation / FEC coding levels ranging from BPSK to 256 QAM dual payload MIMO
DUPLEX SCHEME
Synchronized Time Division Duplex (TDD) and Half Duplex Frequency Division Duplex (HD-FDD); dynamic or fixed transmit/receive ratio; each TDD-synchronized link requires a Cambium TDD-SYNC synchronization unit5 to provide an accurate timing reference signal
ANTENNA
Integrated flat panel: – 19 dBi
RANGE
250 km (155 miles)
SECURITY
FIPS-197 compliant 128-bit or 256-bit AES encryption (optional) HTTPs and SNMPv3 Identity-based user accounts Configurable password rules User authentication and RADIUS support Event logging and management; optional logging via syslog
ETHERNET BRIDGING
PROTOCOL
IEEE 802.3
USER DATA THROUGHPUT
Dynamically variable up to 300 Mbps Maximum conditions – 2x2, 30 MHz channel, 256QAM
LATENCY
1 – 3 ms one-direction latency
QoS
8 Queues
PACKET CLASSIFICATION
Layer 2 and Layer 3 IEEE 802.1p, MPLS, Ethernet priority
PACKET PERFORMANCE
Line rate ( >850K packets per second)
FRAME SUPPORT
Jumbo frame up to 9600 bytes
FLEXIBLE I/O
2 x Gigabit Ethernet copper ports: Gigabit Port 1: data + PoE power input Gigabit Port 2: 802.3at PoE output port (optional) SFP port (single-mode fiber, multi-mode fiber, and copper Gigabit Ethernet options available)
T1/E1 TDM SUPPORT
8 x T1/E1 TDM module (optional Network Indoor Unit) G.823-compliant timing DC power input (compatible with AC+DC Power injector output)
T1/E1 LATENCY (ONE WAY)
1 to 3 ms typical depending on range, bandwidth, modulation mode and number of E1/T1 ports; accurate T1/E1 latency figures can be determined for any given configuration using the Cambium PTP LINKPlanner
MANAGEMENT AND INSTALLATION
LED INDICATORS
Power status, Ethernet link status, and activity on AC+DC Power Injector
NETWORK MANAGEMENT
In-band and out-of-band management (OOBM)
SYSTEM MANAGEMENT
IPv4/IPv6 dual-stack management support Web access via browser using HTTP or HTTPS/TLS SNMP v2c/v3, MIB-II and proprietary PTP MIB Cambium Wireless Manager, WM 4.0/SP4 or higher Online in-band spectrum analyzer (no impact on payload traffic or network operation)
INSTALLATION
Built-in audio and graphical assistance for link alignment and optimization
CONNECTION
Distance between outdoor unit and primary network connection: up to 330 feet (100 meters) using Power-over ethernet; longer distances up to 984 feet (300 meters) can be achieved using fiber interface
PHYSICAL AND ENVIRONMENTAL
DIMENSION AND WEIGHT
Integrated outdoor unit (ODU): Width 207mm (8.2”), Height 306mm (12.0”), Depth 69mm (2.7”) Weight: 2.24 kg (4.9 lbs) – ODU, 0.8 kg (1.8 lbs) - Bracket
OPERATING TEMPERATURE
-40° to +140° F (-40° to +60° C), including solar radiation
DUST/WATER INTRUSION PROTECTION
Dust and water intrusion protection IP66 and IP67
WIND SPEED SURVIVAL
200 mph (322 kph)
POWER SUPPLY
Two options: AC power injector: 32° to 104° F (0° to +40° C); 35 W; 90-240 VAC, 50/60 Hz Dimensions: Width 5.2” (132mm), Height 1.4” (36mm), depth 2” (51mm) AC + DC power injector: -40° to 140° F (-40° to +60° C); 70 W; 90-240 VAC, 50/60 Hz Dimensions: Width 9.75” (250 mm), Height 1.5” (40 mm), depth 3” (80 mm)
POWER CONSUMPTION
30 W maximum
ENVIRONMENTAL AND REGULATORY
PROTECTION AND SAFETY
UL60950-1; IEC60950-1; EN60950-1; CSA-C22.2 no. 60950-1; CB approval for Global
RADIO
4.9 GHz: FCC Part 90y, Rss-111 5.x GHz: FCC Part 15, sub-parts 15C and 15e; RSS 210 issue 8; EN 302 502; EN 301 893 EIRE Comreg 02/71R1, UK approval to IR2007
PTP 650L
Documentation
