PTP 650 Connectorized
Specifications
RADIO TECHNOLOGY
MODEL
PTP 50650
RF BANDS
Wide-band operation 4.9 to 6.05 GHz (Allowable frequencies and bands are dictated by individual country regulations. The most common bands are listed here.) 4.940 – 4.990 GHZ (Public Safety) 5.15 – 5.25 GHZ 5.25 – 5.35 GHZ 5.470 – 5.725 GHZ 5.725 – 5.850 GHZ 5.825 – 6.050 GHZ
CHANNEL SIZES
5, 10, 15, 20, 30, 40, and 45 MHz channels Channel sizes depend on individual country regulations
SPECTRAL EFFICIENCY
10 bps/Hz maximum
CHANNEL SELECTION
By Dynamic Spectrum Optimization or manual intervention; automatic selection on start-up and continual self-optimization to avoid interference
MAXIMUM TRANSMIT POWER
Up to 27 dBm at BPSK; up to 23 dBm at 256 QAM
SYSTEM GAIN
Integrated: Up to 164 dB with 20 MHz channel and integrated 23 dBi antenna; varies with modulation mode, channel size and spectrum Connectorized: Varies with modulation mode and antenna type
RECEIVER SENSITIVITY
-98 dBm with 5 MHz channel
MODULATION / ERROR CORRECTION
Fast Preemptive Adaptive Modulation featuring 13 modulation / FEC coding levels ranging from BPSK to 256 QAM dual payload MIMO
DUPLEX SCHEME
Time Division Duplex (TDD) Adaptive or fixed transmit/receive duty cycles. Split frequency operation allows separate transmit and receive frequencies where allowed by regulation. Optional TDD synchronization using PTP-SYNC Module
ANTENNA
Connectorized: Can operate with a selection of separately-purchased single- and dual-polarity antennas through 2 x N-type female connectors (local regulations should be checked prior to purchase)
RANGE
Up to 124 miles (200 km)
SECURITY
FIPS-197 compliant 128/256-bit AES Encryption (optional) HTTPS and SNMPv33 Identity-based user accounts Configurable password rules User authentication and RADIUS support Event logging and management; optional logging via syslog Disaster recovery and vulnerability management
ETHERNET BRIDGING
PROTOCOL
IEEE 802.3
USER DATA THROUGHPUT
Dynamically variable up to 450 Mbps Maximum conditions – 2x2, 45 MHz channel1 , 256 QAM Flexible spectral efficiency / capacity licensing model: Lite Capacity: Up to 125 Mbps Mid Capacity: Up to 250 Mbps Full Capacity: Up to 450 Mbps Also available with licenses limiting maximum channel bandwidth
LATENCY
1 – 3 ms one-direction latency
QoS
8 Queues
PACKET CLASSIFICATION
Layer 2 and Layer 3 IEEE 802.1p, MPLS, Ethernet priority
PACKET PERFORMANCE
Line rate ( >850K packets per second)
TIMING TRANSPORT
Synchronous Ethernet; IEEE 1588v2
FRAME SUPPORT
Jumbo frame up to 9600 bytes
FLEXIBLE I/O
2 x Gigabit Ethernet copper ports: Gigabit Port 1: Data + PoE power input Gigabit Port 2: 802.3at PoE output port SFP port (single-mode fiber, multi-mode fiber, and copper Gigabit Ethernet options available)
T1/E1 TDM SUPPORT
8 x T1/E1 TDM (Network Indoor Unit (NIDU)) G.823-compliant timing DC power input (compatible with AC+DC Power Injector output)
T1/E1 LATENCY (ONE WAY)
1 to 3 ms typical depending on range, bandwidth, modulation mode and number of T1/E1 ports; accurate T1/E1 latency figures can be determined for any given configuration using the Cambium PTP LINKPlanner
MANAGEMENT & INSTALLATION
LED INDICATORS
Power status, Ethernet link status, and activity on Extended Range PoE supply
NETWORK MANAGEMENT
In-band and out-of-band management (OOBM)
SYSTEM MANAGEMENT
IPv6/IPv4 dual-stack management support Web access via browser using HTTP or HTTPS/TLS3 SNMP v1, v2c and v3, MIB-II and proprietary PTP MIB Cambium Wireless Manager, WM 4.0/SP4 or higher Online spectrum analyzer (no impact on payload traffic or network operation)
INSTALLATION
Built-in audio and graphical assistance for link optimization
CONNECTION
Distance between outdoor unit and primary network connection: up to 330 feet (100 meters) using Power-over-Gigabit Ethernet; longer distances up to 984 feet (300 meters) can be achieved using fiber interface
PHYSICAL
DIMENSIONS
Integrated Outdoor Unit (ODU): Width 371mm (14.6”), Height 371mm (14.6”), Depth 81mm (3.2”) Connectorized ODU: Width 204mm (8.0”), Height 318mm (12.5”), Depth 90mm (3.5”)
WEIGHT
Integrated ODU: 4.1 kg (8.95 lbs) including bracket Connectorized ODU: 3.1 kg (6.8 lbs) including bracket
OPERATING TEMPERATURE
-40° to +140° F (-40° to +60° C), including solar radiation
DUST-WATER INTRUSION PROTECTION
IP66 and IP67
WIND SPEED SURVIVAL
200 mph (322 kph)
POWER SUPPLY
Two options: AC power injector: 32° to 104° F (0° to +40° C); 35 W; 90-240 VAC, 50/60 Hz Dimensions: Width 5.2” (132mm), Height 1.4” (36mm), Depth 2” (51mm) AC + DC power injector: -40° to 140° F (-40° to +60° C); 70 W; 90-240 VAC, 50/60 Hz Dimensions: Width 9.75” (250 mm), Height 1.5” (40 mm), Depth 3” (80 mm)
POWER CONSUMPTION
30 W maximum (up to 70 W with 802.3at device on auxiliary port)
ENVIRONMENTAL & REGULATORY
PROTECTION AND SAFETY
UL60950-1; IEC60950-1; EN60950-1; CSA-C22.2 NO. 60950-1; CB approval for Global
RADIO
4.9 GHz: FCC Part 90Y, RSS-111 5.x GHz: FCC Part 15, sub-parts 15C and 15E; RSS 210 Issue 8; EN 302 502; EN 301 893 Eire ComReg 02/71R1, UK Approval to IR2007
EMC
Europe – EN 301 489-1 and -4
