PTP 550
Specifications
RADIO TECHNOLOGY
RF BANDS
Wide-band operation 5.170 to 5.980 GHz (Allowable frequencies and bands are dictated by individual country regulations)
CHANNEL SIZES
Dual independent channels, each channel configurable as 20, 40 & 80 MHz
SPECTRAL EFFICIENCY
8.5 bps/Hz maximum
CHANNEL SELECTION
Fixed frequency or Dynamic Channel Selection (DCS)*
ETHERNET BRIDGING
PROTOCOL
IEEE 802.3
LATENCY
1-3 milliseconds one direction
PACKET CLASSIFICATION
Layer 2 and Layer 3 IEEE 802.1p, Ethernet priority
MANAGEMENT
NETWORK MANAGEMENT
T In-band management
SYSTEM MANAGEMENT
IPv6/IPv4 dual-stack management support SNMPv2c, https, WPA2-PSK Online spectrum analyzer (no impact on payload traffic)
PHYSICAL
DIMENSIONS
Integrated Outdoor Unit (ODU): Width 305mm (12”), Height 305mm (12”), Depth 56mm (2.2") Connectorized Outdoor Unit (ODU): Width 177mm (7”), Height 280mm (11”), Depth 89mm (3.5”)
WEIGHT
Integrated Outdoor Unit (ODU): 2.2 kg (4.85 lbs) including bracket Connectorized Outdoor Unit (ODU): 1.6 kg (3.5 lbs) including bracket
DUST- WATER INTRUSION PROTECTION
IP66 and IP67
