The PTP 45700 Beam Steering ODU with integrated Smart Antenna provides electronic beamforming that allows for easy tactical installation and best-in-class interference mitigation in addition to the industry-leading spectral efficiency and processing capabilities of the PTP 700 family of products.
Specifications
RADIO TECHNOLOGY
RF BANDS
Wide-band operation 4.400 to 5.875 GHz
CHANNEL SIZES
5, 10, 15, 20, 30, 40, and 45 MHz channels
SPECTRAL EFFICIENCY
10 bps/Hz maximum
CHANNEL SELECTION
By Dynamic Spectrum Optimization™ (DSO) or manual intervention; automatic selection on start-up and continual self-optimization to avoid interference
MAXIMUM TRANSMIT POWER
29 dBm
SYSTEM GAIN
Up to 166 dB
MODULATION / ERROR CORRECTION
Fast Preemptive Adaptive Modulation featuring 13 modulation / FEC coding levels ranging from BPSK to 256 QAM dual payload MIMO
ANTENNA
Integrated flat panel Boresight gain (dBi): 21.4 @ 4.4, 22.1 @ 5.0, 21.0 @ 5.875 GHz + 60 / - 60º gain (dBi): 14-16 dBi
SECURITY
128/256-bit AES Encryption (optional) HTTPS and SNMPv3, user authentication and RADIUS support Identity-based user accounts Configurable password rules Event logging and management; optional logging via syslog disaster recovery and vulnerability management FIPS-197 compliant
ETHERNET BRIDGING
PROTOCOL
IEEE 802.3
LATENCY
1 – 3 ms one-direction latency
QoS
Extensive QoS supporting up to 8 Queues (PTP mode) and 4 Queues (HCMP mode)
PACKET CLASSIFICATION
Layer 2 and Layer 3 IEEE 802.1p, MPLS, Ethernet priority
PACKET PERFORMANCE
Line rate ( >850K packets per second)
TIMING TRANSPORT
Synchronous Ethernet; IEEE 1588v2
MANAGEMENT & INSTALLATION
NETWORK MANAGEMENT
In-band and out-of-band management (OOBM)
SYSTEM MANAGEMENT
IPv6/IPv4 dual-stack management support Web access via browser using HTTP or HTTPS/TLS SNMP v1, v2c and v3, MIB-II and proprietary PTP MIB Online spectrum analyzer (no impact on payload traffic or network operation)
INSTALLATION
Built-in audio and graphical assistance for link optimization (when automatic beam steering is disabled)
PHYSICAL
DIMENSIONS
581 x 595 x 84 mm (22.9 x 23.4 x 3.3 in)
WEIGHT
9.1 kg (20.1 lbs)
OPERATING TEMPERATURE
-40° to 60°C (-40° to 140°F)
SHOCK, VIBRATION, TEMPERATURE, HUMIDITY
MIL-STD-810H
DUST-WATER INTRUSION PROTECTION
IP66 and IP67
ENVIRONMENTAL & REGULATORY
REGULATORY PROTECTION AND SAFETY
UL60950-1 and -22; IEC60950-1 and -22; EN60950-1 and -22; CSA-C22.2 No. 60950-1; CSA-C22 No. 60950-22-7; CB approval for Global
RADIO
4.9 GHz: FCC Part 90Y, RSS-111 5.x GHz: FCC Part 15, sub-parts 15C and 15E; RSS 247 Issue 1; EN 302 502; EN 301 893; EN 302 625; Eire ComReg 02/71R1, UK Approval to IR2007
EMC
Europe – EN 301 489-1 and -17; FCC Part 15B Class B
