PTP 450 is Cambium Networks’ first point-to-point backhaul solution offered in 3.65 GHz lightly licensed and 3.5 GHz licensed bands, in addition to 5 GHz. PTP 450 is optimized for reach, reliability and throughput in a compact form factor, making it ideal for enterprise access services such as data, VoIP, video conferencing, video surveillance and backup connection service.
PTP 450
Specifications
INTERFACE
MAC (Media Access Control) Layer
Cambium Networks proprietary
Physical Layer
14x14 Multi-User MIMO OFDM
Ethernet Interface
100/1000BaseT, full duplex, rate auto negotiated (802.3 compliant), SFP support up to 2.5NBase-T
Protocols Used
IPv4, UDP, TCP, IP, ICMP, Telnet, SNMP, HTTP, FTP
Network Management
HTTP, HTTPS, Telnet, FTP, SNMP v3
VLAN
802.1ad (DVLAN Q-inQ), 802.1Q with 802.1p priority, dynamic port VID
PERFORMANCE
Subscriber Per Sector
Up to 238
ARQ
Yes
Maximum Deployment Range
Up to 40 miles (64 km)
Latency
10 ms, typical
GPS Synchronization
Yes, via Autosync (CMM5 or UGPS)
Quality of Service
Diffserv QoS
LINK BUDGET
Antenna Beam Width (Azimuth)
Integrated Sector Array
Antenna Beam Width (Elevation)
2° Electrical Downtilt, 8° Elevation (with Null Fill)
Maximum EIRP
+42 dBm (or up to maximum allowed by regulation)
