cnMaestro X is a simple yet sophisticated next-generation network management solution for Cambium Networks wireless and wired solutions. The system offers elastic scalability and single-pane-of-glass management to deliver secure, end-to-end network and wireless lifecycle management with zero-touch provisioning, monitoring, and troubleshooting capabilities. It simplifies operations and ongoing maintenance.
Advanced Features
MSP DASHBOARD
Managed Service Providers (MSPs) can differentiate their brand to address specific sub-markets in their service area.
APIS AND WEBHOOKS
Restful APIs and Webhooks for integration with existing OSS/BSS systems and event monitoring.
X ASSURANCE
Rapidly troubleshoot network issues using AI-powered root cause analysis with proactive resolution, ensuring SLA’s are met and preventing client impact.
SUPPORT
Cambium Care Pro – 24×7 accelerated access to Level 2 technical support and all software updates/ upgrades.
Check out the cnMaestro guided demonstration
Other Key Features
Built for scale and security at all levels
Devices connect to cnMaestro cloud management using SSL-enabling deployments without changes to the firewall configuration. Cambium intelligent edge architecture enables fault-tolerant networks where the network continues to operate even when the cloud is unreachable due to a WAN outage. With cnMaestro Essentials, you can manage networks with up to thousands of sites and up to 10,000 devices.
Zero-touch provisioning
Create, provision, monitor and manage the entire network of wireless and wired devices from a single dashboard login with key performance metrics, alarms and alerts. The cloud-first UI design is easy to learn and apply across the portfolio. cnMaestro network management helps network administrators simplify operations and deliver an optimal client experience.
Deployment flexibility and TCO
Choice of public cloud, private cloud, or on-premises deployment with best TCO. cnMaestro network management helps lower operating cost and accelerate return on investment by not requiring Wi-Fi controllers, which reduces the complexity and cost of deploying Wi-Fi networks.
Supports network hierarchy
Enables easy configuration, monitoring and debugging at network nodes and decreasing operational costs. This especially becomes critical for large or small distributed networks with small on-site IT staff.
Videos
VisionNet MSP Case Study
