Service providers constantly face the challenge of delivering high-capacity broadband while working within limited spectrum availability. The new ePMP Force 4518 Subscriber Module (SM) from Cambium Networks is a game-changer in fixed wireless broadband solutions, providing high performance at a highly competitive price in a new small form-factor. Small form-factor SMs with panel antennas have been the most popular form factor for network operators in dense areas and where simple installations and aesthetics are critical. Designed for both Point-to-Multipoint (PMP) and Point-to-Point (PTP) deployments, the ePMP Force 4518 offers a range of benefits, including an ultra-compact form factor, simplified installation, cost-effectiveness, and combining next-generation 802.11ax technology with the proven ePMP platform. Let’s explore how this new SM can transform wireless connectivity.
1. Small Form Factor: Powerful Yet Discreet
The ePMP Force 4518 sports a sleek, flat-panel design that eliminates the need for an additional dish, making it an aesthetically pleasing choice for residential and business deployments.
- No additional dish required – Unlike larger SMs that require bulky reflectors, the 4518 integrates an 18 dBi flat-panel antenna, keeping the design compact and minimizing installation footprint.
- Urban and suburban-friendly design – Whether mounted on rooftops or walls, this SM blends seamlessly into its surroundings, making it an ideal solution for areas where aesthetics matter.
- Lightweight and durable – Weighing only 1.2 kg (2.65 lbs), the ePMP Force 4518 is easy to handle, transport, and install, without compromising durability.
2. Ease of Installation: Simplified Deployment with Sector Panel Alignment
Installation time and complexity can make or break an SM’s adoption in the field. The ePMP Force 4518 makes deployment significantly easier with its sector-panel design.
- Easy to align – Unlike traditional dish-based SMs, which require precise alignment to establish a strong link with the Access Point (AP), the wide-angle panel antenna of the Force 4518 provides greater flexibility in aiming for faster installations.
- Integrated pole mount hardware – The unit includes an easy-to-mount system, enabling quick and secure installations.
- Plug-and-play setup with cnMaestro™ – As part of Cambium’s ONE Network, the ePMP Force 4518 seamlessly integrates with cnMaestro™, providing zero-touch provisioning, remote monitoring, and streamlined network management.
3. Cost-Effective Broadband: A High-Performance Solution at a Budget-Friendly Price
Cost is a major consideration when scaling broadband networks, and the ePMP Force 4518 delivers exceptional performance at a fraction of the cost of comparable solutions.
- Optimized for affordability – Built to deliver high-speed broadband without the need for costly external antennas or complex installations.
- Multi-use application – The device supports both Point-to-Multipoint (PMP) and Point-to-Point (PTP) configurations, allowing service providers to maximize their investment across multiple deployment scenarios.
- Check with your distributor for pricing – The ePMP Force 4518 is designed to be one of the most cost-effective solutions on the market. Contact your local Cambium Networks distributor to learn how much you can save compared to traditional SMs.
4. Combines Next-Generation 802.11ax Technology With the Proven ePMP Platform
Wireless performance is at the heart of any SM, and the ePMP Force 4518 is engineered to deliver top-tier speeds and reliability with the proven ePMP platform that has more than 4 million radios deployed. The ePMP 4000 Series leverages all the scalability, performance and cost-effectiveness and now leverages the latest 802.11ax (Wi-Fi 6) technology as its underlying chipset.
- High-speed connectivity – Supports 1024-QAM and 80 MHz channel widths, enabling gigabit-class speeds with ultra-low latency.
- Optimized for ePMP 4500 Series APs – The Force 4518 fully integrates with MU-MIMO technology, allowing the AP to communicate with multiple SMs simultaneously, increasing network efficiency.
- QoS prioritization for voice, video, and data – With advanced Quality of Service (QoS) features, service providers can deliver high-performance broadband while ensuring superior user experience for VoIP, streaming, and business-critical applications.
- Secure and reliable – Features 128-bit AES encryption and enterprise-grade security protocols, ensuring safe and interference-resistant connectivity.
Why Choose the ePMP Force 4518?
The ePMP Force 4518 Subscriber Module is a perfect blend of performance, affordability, and ease of deployment. Whether you are expanding your fixed wireless network, improving coverage in suburban and rural areas, or looking for a cost-effective alternative to fiber, this SM delivers high-speed connectivity at an unbeatable price.
✔ Compact and discreet – No dish required, small and lightweight. ✔ Easy to install – Sector panel alignment reduces setup time. ✔ Super affordable – Competitive pricing makes large-scale deployments feasible. ✔ Next-gen 802.11ax technology – High-capacity, MU-MIMO-enabled, and optimized for performance.
If you’re looking for a cost-effective, high-performance wireless broadband solution, the ePMP Force 4518 is your best bet.
For more information, visit Cambium Networks or contact your authorized distributor.
