Minute with Morgan: Wireless Takes Center Stage in a Tech-Neutral BEAD Landscape
By Morgan Kurk
The Department of Commerce’s decision to revamp the BEAD program is a turning point for broadband in the U.S. By eliminating constraints and shifting to a tech-neutral, outcome-driven approach, the path is now easier for states to deliver high-speed internet access quickly, efficiently, and cost-effectively.
At Cambium Networks, we welcome this change — and we’re ready.
Wireless is Working — At Scale and At Speed
Across our wireless portfolio, we’ve engineered solutions that not only meet but exceed the 100/20 Mbps performance standard. Operators using Cambium equipment are delivering reliable, high-throughput broadband across rural, suburban, and urban markets — often in areas where fiber simply doesn’t pencil out.
Here’s what’s powering that momentum:
  • ePMP™ 4000 series: Our latest generation of fixed wireless delivers up to 1 Gbps throughput in real-world conditions with enhanced spectral efficiency and low latency. It’s ideal for operators building high-capacity access networks while managing spectrum effectively.
  • PMP 450v 2×2: Deployed across both 5 GHz and 6 GHz bands, this platform supports over 600 Mbps per subscriber and is already in active use delivering BEAD-compliant service.
  • 60 GHz cnWave™: Providing fiber-like speeds wirelessly, ideal for dense environments or extending networks without trenching.
  • Licensed and unlicensed microwave backhaul: Built to connect the unconnected quickly — and built to last.
It’s not just a toolbox — it’s a wireless strategy that empowers operators to connect more homes, faster, with a lower total cost of ownership.
Preventing Overbuild, Preserving Progress
One of the smartest aspects of this BEAD shift is what it protects. In the previous model, working wireless networks were at risk of being overbuilt by fiber — even when the wireless service met or exceeded performance goals. That’s both unnecessary and hurts deployments in unserved areas.
Now, with a shift toward results, well-designed wireless deployments can stand on their own merit. This protects existing investments and encourages smarter planning at the state level.
Where Cambium Stands
Cambium Networks has focused on delivering high-performance, cost-efficient solutions that scale in real deployments across the U.S. and around the world. We’ve proven that wireless can deliver on BEAD objectives, and we’re ready to partner with operators and state leaders as they re-evaluate plans under the new guidance.
Let’s build networks that work — and last.
Our team is actively supporting service providers and grant stakeholders with design guidance, performance documentation, and deployment best practices. The future of broadband is more flexible and financially prudent — and Cambium Networks is proud to be helping lead the way.
Let’s talk about how wireless can power your BEAD strategy.
Published April 2, 2025
